2003 Honda Accord Wire location
INDORUWET
  • 2003 HONDA ACCORD
  • 4 CYL
  • 73,000 MILES
Exactly where is the VSS wire and the Tach wire?
I am in the process of installing an after market cruise control, and the last two wires need to be connected to the connections mentioned above.
A small pictorial representation would be greatly appreciated if at all possible.
TIA
Do you
have the same problem?
Friday, January 9th, 2009 AT 12:32 AM
BLUELIGHTNIN6
  • EXPERT
The vehicle speed sensor is located on top of the transaxle. If the vehicle is equipped with a tachometer, then it will be ran by the speed sensor as well. Diagram of wires from the speed sensor is below. I have highlighted the appropriate wires for your convenience.
NOTE: The blue wire continues on to the PCM off screen.
http://www.2carpros.com/forum/automotive_pictures/261618_Noname_96.jpg
Hope this helps..
Thanks for using 2carpros.com!
Friday, January 9th, 2009 AT 1:18 AM
INDORUWET
Uhmm. Thanks a million but.
I apologise for not mentioning before, the wires are supposed to be:
1 - VSS = Blue/White
2 - Tach = Yellow/Green
Some more info I found:
Where is/could be
1 - *location 4-31 @ ECM?
2 - *Location 16 on distributor?
Could they be somewhere on that box that is on top of the *middle tunnel*,
on the right side (passenger side)?
The wires to be connected are inside the cabin.
Thank you for efforts
Friday, January 9th, 2009 AT 9:37 AM
BLUELIGHTNIN6
  • EXPERT
My apologies. I have found and posted the VSS wire for you located inside of cab. It is located under the middle of the dash at the PCM. The tachometer signal wire (yellow/green) will be located behind the instrument cluster or in left hand side of steering column.
When hooking up a cruise control system, the tach is usually not required for the cruise control to work, it is just a safety feature. If the engine RPM's reach a certain rate (usually at or above 4000) the cruise control will disengage preventing any possible harm to the engine.
http://www.2carpros.com/forum/automotive_pictures/261618_Noname_98.jpg
Hope this helps..
Friday, January 9th, 2009 AT 11:32 AM
INDORUWET
Yep, it sure did. I had a feeling that that was where the VSS wire would be but the numbers did not correspond.
Now I know, and thank you guys !
Saturday, January 10th, 2009 AT 12:03 AM
Recommended Guides
