2003 Honda Accord Engine misses or jerks
CW4
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 152,619 MILES
When I reach around 40 miles an hour, my engine starts of run rough (misses or jerks). If I slow down or accelerate to 50 miles an hour, it goes away.
Do you
have the same problem?
Saturday, September 11th, 2010 AT 10:15 AM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Saturday, September 11th, 2010 AT 10:28 AM
Recommended Guides
