2003 Honda Accord Can not Move gear shift into drive at tim
SVT1111
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 70,000 MILES
Can start car but sometimes can't get gear shift control to release into the drive postiion (brake is engaged). After trying a few times it usually goes. What is causing this and how expensive is it to repair?
Do you
have the same problem?
Sunday, November 2nd, 2008 AT 6:57 PM
KHLOW2008
  • EXPERT
Hi svt1111,
When it happens, check if the brake lights are working. If not, then you need to check the brake switch at peddal.
If brake lights are working and unable to engage, listen for a clicking sound from near the gear shift, if none, you need to check the interlock fuse and solenoid operations.
Prices depends on what needs to be done.
Monday, November 3rd, 2008 AT 3:40 PM
Recommended Guides
