2000 Honda Accord Wont Start
EVY
  • 2000 HONDA ACCORD
  • 4 CYL
  • AWD
  • 168,000 MILES
My car was working good up till today. I tried starting it and it wouldnt turn on! Could it be I need a new battery?
Do you
have the same problem?
Wednesday, October 29th, 2008 AT 11:04 PM
KHLOW2008
  • EXPERT
Hi Evy,
It is possible the battery decided to quit. Before replacing the battery, check the battery voltage.
It could be a bad terminal connections. Disconnect the battery terminals and clean them up by pouring some hot water on them if they looked oxidised. Reconnect and test if it works.
If jump starting is required, then the volatage should be low. Test battery and charging condition before replacement.
Sunday, November 2nd, 2008 AT 12:41 AM
Recommended Guides
