1999 Honda Accord engine missing while running
CHESSSTER@PEOPLEPC.COM
  • 1999 HONDA ACCORD
  • 4 CYL
  • FWD
  • 113,111 MILES
113111
Do you
have the same problem?
Sunday, May 9th, 2010 AT 4:26 PM
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Monday, May 10th, 2010 AT 6:14 AM
Recommended Guides
