1998 Honda Accord Stating fault
SONNY_ENGLISH
  • 1998 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 155,000 MILES
I have a starting fault on my honda. Its comes and goes, but its becoming more frequent now. Upon starting, the dash goes blank. The engine catches then dies. It will do this two or three times. Then it will start fine. The green key symbol flashes for longer then it re-starts. It hasn't failed when driving, but it did the other day, im a afaid it will leave me stranded. Its a normal key, so I don't think it is coded. I haven't got access to and diagnostic equipment, fo fault find. I suspect it may be the inhibiter swith on the clutch, of the ignition barrel. What do you think it is?
Do you
have the same problem?
Thursday, October 15th, 2009 AT 2:09 PM
F4I_GUY
  • EXPERT
Sounds like an ignition switch issue to me.
Thursday, October 15th, 2009 AT 7:08 PM
Recommended Guides
