1998 Honda Accord Q:12/5/08 POWER DOOR LOCKS
MSFIXIT02
  • 1998 HONDA ACCORD
  • 6 CYL
  • FWD
  • 91,000 MILES
1. Does Power door locks include the knob, rod, latch & actuator or are can one function without the other?
2. My passenger door will not open, the locking swithces will not lock or unlock my door (have to pull up knob manually), and the remote will not lock or unlock the door ( I have to use the key & then set the alarm).
3. How do you know which of the above caponets has malfunctioned or do they all operate together.
4. Do you have to break the door or latch to figure out the problem?
5. What are the donation question ranges (I don't know an appropirate amt to donate)?
Thank you
Do you
have the same problem?
Friday, December 5th, 2008 AT 3:08 PM
ZACKMAN
1. Power door lock includes the switch, circuit breaker and actuator. Everything else are parts of manual door lock. All parts of manual lock work together, and all power lock work together, in conjunction with the manual lock.
2 and 3. Your actuator is bad.
4. Remove the door panel, locate and replace the actuator.
5. It is all up to you. We thank you for your donation.
Friday, December 5th, 2008 AT 11:49 PM
MSFIXIT02
Thank you very much.
Saturday, December 6th, 2008 AT 2:38 PM
Recommended Guides
