1998 Honda Accord Hard shifts
MSUMNERS
  • 1998 HONDA ACCORD
  • 6 CYL
  • FWD
  • 126,000 MILES
My 98 Accord is shifting hard & with a jerk when shifting from 1st into 2nd, or 2nd into 3rd gear. Also, when I come to a stop, if shifts hard back into first gear. I topped off the transmission fluid and it still does it. Any ideas?
Do you
have the same problem?
Tuesday, June 1st, 2010 AT 9:37 PM
KHLOW2008
  • EXPERT
Hi msumners,
Is the Check Engine Light showing or D4 indicator light blinking while driving?
Did you try to retrieve for trouble codes?
Thursday, June 3rd, 2010 AT 10:22 AM
MSUMNERS
Just checked the codes at a repair shop - nothing came up for the transmission, only some emissions thing(ECV). And the D4 light hasn't been blinking.
Thursday, June 3rd, 2010 AT 10:54 AM
KHLOW2008
  • EXPERT
When no trouble codes are present, harsh shifting could be caused by the following :
Excessive Shock Or Flare In All Shift Lever Positions
" A/T Clutch Pressure Control Solenoid Valves "A" Or "B" Assembly Defective
" CPC Valve "A" Defective
" CPC Valve "B" Defective
" Foreign Material In Separator Plate Orifice
Excessive Shock Or Flare During 1-2 Or 2-1 Shift
" Shift Control Solenoid Valve "C" Defective
" 2nd Clutch Pressure Switch Defective
" Shift Valve "C" Defective
" 1st Accumulator Defective
" 2nd Accumulator Defective
" 1st Check Ball Stuck
" 2nd Check Ball Stuck
" 1st Clutch Defective
" 2nd Clutch Defective
Excessive Shock Or Flare During 2-3 Or 3-2 Shift
" 3rd Clutch Pressure Switch Defective
" 3rd Accumulator Defective
" 3rd Clutch Defective
Thursday, June 3rd, 2010 AT 11:26 AM
MSUMNERS
Thanks! I'll pass this on to my mechanic who is going to change out the transmission fluid tomorrow.
Thursday, June 3rd, 2010 AT 1:35 PM
KHLOW2008
  • EXPERT
You're welcome.
Hope it is nothing serious.
Thursday, June 3rd, 2010 AT 1:57 PM
Recommended Guides
