1996 Honda Accord Replacing a thermostat
TOMHONDA
  • 1996 HONDA ACCORD
  • 4 CYL
  • 165,000 MILES
Where can I find instructions to replace a thermostat on a Honda. Use to own a Jetta and have replaced a thermostat. Fairly comfortable but not sure where it is located on the Honda.
Do you
have the same problem?
Friday, May 16th, 2008 AT 5:10 PM
You'll find the thermostat behind the valve cover almost all the way to the left. It will be just underneath the distributor. You will need to disconnect the main upper radiator hose, two electrical plugs and three mounting bolts
Friday, May 16th, 2008 AT 8:03 PM
