1996 Honda Accord radiator evaporates water at a fast pace
AHYSAH
  • 1996 HONDA ACCORD
  • 6 CYL
  • FWD
  • 106,000 MILES
I will check the radiator, maybe every 2 days and will find that is almot completely empty.
After adding water the car is fine but then the water will eveporate from the radiator.
The temperature gauge did go to extremely hot once, but with the radiator full the gauge stay at the middle line.
Could the engine be severly damaged with this kind of issue.
Do you
have the same problem?
Friday, January 15th, 2010 AT 9:41 PM
BMRFIXIT
  • EXPERT
Coolant system need to be pressure checked
and also check headgasket
running engine white overheating will cause internal failure
if it hasn't happened yet
Friday, January 15th, 2010 AT 9:52 PM
