1996 Honda Accord
TONY1980
  • 1996 HONDA ACCORD
1996 Honda Accord
misfire between 2000 an 3000 rpm
Do you
have the same problem?
Friday, May 14th, 2010 AT 12:16 PM
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Saturday, May 15th, 2010 AT 8:39 PM
Recommended Guides
