Water on floor
PATEL703
  • 1998 HONDA ACCORD
  • V8
  • 4WD
  • 169,000 MILES
The driver side floor is wet. I dont know where it comes from but it isolated to an area that is away from the pedals and basically in the portion of the floor directly in front of the seat. If I leave the mat on the water collects on the bottom of the mat and fogs up the car. The leak must be minor because its not that wet but more moist and damp.
Wednesday, January 20th, 2010 AT 9:54 PM
HONDA TECH 1818
  • 536 POSTS
The leak could be coming from the moon roof drain hose, remove the driver's side kick panel (Plastic cover by your left foot, under dash) to inspect the drain hose and the drain valve connection. The drain hose should be connected to the drain valve.
Attached below is a drawing of where the drain goes
Thursday, January 21st, 2010 AT 1:03 AM
KARYNO
  • 1995 HONDA ACCORD
  • 148,000 MILES
'95 Honda Accord 148,000 miles
The carpet on the floor behind the driver's seat is very wet. Nowhere else. Window doesn't leak. Any ideas?
Thank you,
Karyn
Thursday, January 2nd, 2020 AT 6:41 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
That can be coming in from many different places starting with the roof seam, rear window seal, side window seal, door seal, etc. The way you find it is to remove all the inside trim and look for the stain path or sit inside while someone sprays the car down.
SHANELANDRY
  • 1994 HONDA ACCORD
There is cold water that drips from somewhere under the glove box. When I turn I can hear the water sloshing around. If I make a hard turn it will pour out near the gas pedal. The water is cold, so I am assuming that it is some type of drain from the a/c that a hose has either come loose or broken. Can anyong give me any hints?
BRUCE HUNT
  • 3,753 POSTS
There are two possibles. One - has it rained halfway recently or have you washed the car? There could be plugged drain on the air intake vent located on the outside of the car right below the windshield. Two - The air conditioner drain is plugged.
SHANELANDRY
The a/c drain was plugged up with something. It wasn't the hose those. I pulled off the hose and it was clean. I used a straw and stuck it inside the part where the drain hose connects and sure enough the water started pouring out. Now if I can get my floorboard dry everything will be good to go!
Thanks for your help
BRUCE HUNT
  • 3,753 POSTS
Thanks for replying and congrats on another mission accomplished.
GSAVIN
  • 1996 HONDA ACCORD
  • 6 CYL
  • FWD
  • 90,000 MILES
96 accord has been water tested and came out clean. Seems to have this problem after torrential rain even when parked. It has been mentioned that it could be the heater coil. Water seems to be brownish in color. This problem has happened 2 times in the past year 5-6 months apart. Any ideas and if it is the heater coil approx what would the cost be to repair. Thanks
F4I_GUY
  • 3,302 POSTS
It's called a heater core.
And you must remove the whole dash which is over a 6hr job. The part itself isn't too much, so you are probably looking at around $600-$700 or so because you must flush the coolant system as well.
GSAVIN
Is not the problem. There are drains under the windshield that get clogged with junk and leave the water no place to go. Take off the wipers and the plastic cover. You will see the drain holes. Clear them out. Problem solved.
Thursday, January 2nd, 2020 AT 6:42 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,798 POSTS
Thanks for the follow up. Use 2CarPros anytime, we are here to help. Please tell a friend.
BROMELL55
  • HONDA ACCORD
I wash it or it rains, there is water in the floor of the passenger side. It appears the drain system is clogged up. How can I get to it and clean it?
Thursday, January 2nd, 2020 AT 6:43 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Right upfront, I have not worked on this model, however the basic problem usually lies in the drain for the wiper transmission drain. You may be able to access from the top by removing the cowl that covers where the wiper tranmission lies in, or may need to access it through the area behind the glove box. Maybe picture of the cowl would help if you want to try. Not sure how much help I be on this one. :|
Also, before getting into anything, I would use a hose and try to narrow down if in fact that is the leak source. It may be from a leaking windshield or other sources.
PLAYA132341
  • 1995 HONDA ACCORD
1995 Honda Accord 4 cyl Automatic 193000 miles
I have noticed lately that when there is a heavy rain that sometimes my carpet get wet from underneath usally on the drivers side would there be a reason for that?
Thursday, January 2nd, 2020 AT 6:44 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi playa132341,
That would indicate a leak somewhere and to confirm where the leak is coming from, you would have to flip up the carpet and do a water test with a garden hose to locate the source.
JOEHARRISON
  • HONDA ACCORD
I Drive a 91 Honda Accord With a manual transmission. A couple of weeks ago I looked into the back seat and there was a puddle in the back passenger side. So I lifted the carpet pulled the plug from the middle and drained it. But the puddle keeps coming back and there has been constant rain. The door stuff is all great and nowhere water can come in from. Is it leaking from inside. And from what? I also heard that it could be the sunroof? But the seals are perfect on that too.
BRUCE HUNT
  • 3,753 POSTS
I would suspect anything and not rule out anything. Go to a car wash and watch the water at door window and sunroof. You can also have a partner help out with a hose on the outside of the car.
MOEYANNARIZONA
  • 1994 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 175,000 MILES
I just noticed in the last week cold water leaking on floorboard, it leaks down onto my foot that is on the gas pedal. Same thing is happening on the passengers side but today quite a bit of water leaked onto this side. I also am hearing a sound from the vents on the passenger side, sounds like paper flying around in the vent. What good this be? Thank-you
KHLOW2008
  • 41,815 POSTS
Hi moeyannarizona,
The noise could be due to leaves, plastic or paper in the blower motor compartment.
The water could be condensation from the AC evaporator and it is flooding most probably due to a clogged drain hose.
FAISALNKN
  • 1997 HONDA ACCORD
  • 4 CYL
  • 4WD
  • MANUAL
  • 131,000 MILES
In heavy rain water starts dripping from under the dash board at passenger side. There is a small nosel from it and goes till back passanger seat.
