1995 Honda Accord how to fix the axles bearings?
LAZO22
  • 1995 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 12,000 MILES
How to fix the axles bearings?
Do you
have the same problem?
Sunday, October 12th, 2008 AT 3:07 AM
KHLOW2008
  • EXPERT
Hi Lazo22,
You mean replace them?
You need to remove the brake caliper with mounts.
Remove the rotor.
Remove the CV joint centre nut.
Use slide hammer to take the hub out and press the bearing cone out.
Remove lower arm ball joint.
Remove the CV joint.
Remove the 4 holding bolts and take out bearing.
Installation is by pressing in the hub and the install.
Monday, October 20th, 2008 AT 11:32 AM
Recommended Guides
