1994 Honda Accord not sure whats wrong
GG84
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • 279,000 MILES
My car over heated and i melted the top of my radiator... well i patched the holes, put new oil in and filled the radiator with water and it started fine out side of water squirting out... the next day i started it again and it started fine... well i decided to be brave and take it to work to have my brother look at it.. well not so good. pulled over to a gas station to put water in it.. they didnt have what i was looking for went across the street to another gas station and filled.. when i tried to start it it wouldnt start..towed it to my house and she still wont start.... if u could please help me figure this out .... i would much appreciate it.... gina
http://www.2carpros.com/forum/automotive_pictures/305287_car_pic_2_1.jpg
http://www.2carpros.com/forum/automotive_pictures/305287_car_pic1_1.jpg
Do you
have the same problem?
Tuesday, January 20th, 2009 AT 7:47 PM
KHLOW2008
  • EXPERT
Hi Gina,
I believe not much guessing is required.
The problem should be a damaged head gasket resulting in the compression dropping. Pull out the engine oil dipstick and see if the oil is milky. If yes, the cylinder head and/or gaskert is bad.
Remove the radiator cap and top up with water. Without closing the cap, crank engine and if water shoots out, the head gasket is blown.
Saturday, January 24th, 2009 AT 9:44 AM
Recommended Guides
