1993 Honda Accord Random Starting Problem
56ROC
  • 1993 HONDA ACCORD
Engine Mechanical problem
1993 Honda Accord 4 cyl Two Wheel Drive Automatic
I am having a starting problem with my 1993 Accord. It starts, runs fine for several miles or hours. Then for no outwardly obviously reason it will crank but not start. Let it sit for a 15 -20 minute period, and it will start and run fine. All fuel responsible things seem to be in working order and it has gas in it. Happen last July and went away and now here it is July again and it is back. Maybe a heat issue? Vapor lock?
If anyone can shed some light upon this, I would sincerely apprecite hearing from you.
Thanks,
56roc
Do you
have the same problem?
Sunday, July 6th, 2008 AT 12:35 PM
KHLOW2008
  • EXPERT
Hi 56roc,
Should be the main relay is faulty.
Sunday, July 6th, 2008 AT 1:27 PM
Recommended Guides
