Oil pressure switch?
KMMS88
  • 2002 HONDA ACCORD
  • 4 CYL
  • FWD
  • 160,000 MILES
Can the car car still be driven with a bad oil pressure switch how can I replace it?
Sunday, March 21st, 2010 AT 8:57 PM
KHLOW2008
  • 41,815 POSTS
Here is the location of the oil pressure sensor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, March 21st, 2010 AT 9:00 PM
JUSUF.MEHMEDOVIC
  • 1996 HONDA ACCORD
  • 4 CYL
  • 180,000 MILES
My engine has a oil sensor or oil light problem, how do I troubleshoot the problem to fix?
Friday, January 22nd, 2021 AT 12:03 PM (Merged)
JUSUF.MEHMEDOVIC
I had a low amount of oil in the car, than the oil light started blinking I stopped the car filled it up with oil and the light stopped blinking but when the engine was running for 20 miles and the light began to blink again do you know what might be wrong?
BMRFIXIT
  • 19,053 POSTS
Check if low again on oil
and if so check for leak and check oil pressure switch
JPD1844
  • 1993 HONDA ACCORD
I have a 1992 Honda Accord EX 2.2L with 305650 miles on it and as of Friday the low oil pressure light flashes on and off. It only comes on after driving the car for a while. Sometimes it flashes dim like there might be something wrong with the wire. Well I went to the auto parts store and bought a new filter and oil pressure sensor and I can't find where the sensor is. I think it is right above where the oil filter is, but I am not sure. I was told that the only 3 things that would make that light turn on were the filter caving in on itself, the sensor or the oil pump. This car was owned by a honda dealership employee up until about 6 months ago when I bought it from them. This person always got all the routine maintenance done. Any input on where the oil pressure sensor is and what you think might be causing the problem would be greatly appreciated. Thank You
Friday, January 22nd, 2021 AT 12:04 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Oil pressure switch is located on center rear of engine above oil filter
good luck
JPD1844
Thanks! I got it changed out.
BMRFIXIT
  • 19,053 POSTS
Hope all good
good luck
Just in case others need it in the future. Here is the location and part information for the oil pressure switch. Plus here is a guide that will help with low oil pressure issues:
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Run through this material and let us know what questions you have and we can go from there. Thanks
Friday, January 22nd, 2021 AT 5:11 PM
