1993 Honda Accord
SNVASQUEZD
  • 1993 HONDA ACCORD
Transmission problem
1993 Honda Accord 4 cyl Automatic 200, 00 miles
I have a 1993 automatic transmission accord, it has problems identifying in which gear it is driving, took it to the mechanic he said it gave him a code 5, but it's not giving any other information. The mechanic mention neutral switch or ground problems.
Do you
have the same problem?
Thursday, October 30th, 2008 AT 9:03 AM
KHLOW2008
  • EXPERT
Hi snvasquezd,
DTC # 5 means
1. Short in Shift Position Console switch wire.
2. Faulty Shift Position Console switch.
The problem would result in gears shifting only between 2 and 4.
Does the meter indicator lights for the gear shift positions indicate the correctly?
You need to check the switch which is located under the gear shift console.
Sunday, November 2nd, 2008 AT 12:48 AM
Recommended Guides
