1992 Honda Accord cooling fan comes on now and then after I
MIKE OSBORN
  • 1992 HONDA ACCORD
  • 4 CYL
  • FWD
  • 23,500 MILES
Cooling fan will come on and stay on now and then after ignition has been turned off. Fan will continue to run until battery has completely gone dead. I have stopped the fan by removing the relay.
Do you
have the same problem?
Tuesday, September 30th, 2008 AT 10:44 AM
KHLOW2008
  • EXPERT
Hi mike osborn,
Try swapping the relay, it could be faulty and sticking. The fan would come on for a short while after engine is turned off if the temp is high at the upper hose outlet.
If swapping does not help and the temp is not high with sufficient coolant in radiator, the thermoswitch at upper hose joint on head needs to be replaced.
Saturday, October 18th, 2008 AT 9:00 AM
Recommended Guides
