My windshield wipers will not turn off
DHOG22
  • 1994 HONDA ACCORD
  • 600,000 MILES
My windshield wipers will not turn off when the switch is in off position, yet responds when the switch ask to turn them on. They won't turn off.
The wipers turn on normally but will not stop when the switch is turned off. It will turn off days later but is getting progressively worse.
Friday, May 18th, 2012 AT 3:34 AM
ACRDOWNR
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • 145,000 MILES
Electrical problem
1994 Honda Accord 4 cyl Front Wheel Drive Automatic 145000 miles
1994 Honda Accord windshield wipers won't shut off and now the dash light is out. We have already replaced the switch assembly and think it may be the wiper relay, but we are not able to locate it on the car. Can you help? Also, my daughter said the dash light is out now too. Any ideas on where to start with that? Thanks!
Saturday, April 22nd, 2017 AT 7:22 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi Acrdownr,
The intermittent wiper relay is under the main fuse box under bonnet.
Check for loose or corroded connector under the main fuse box.
Dash lights, check the dimmer control.
DOGBOY52
  • 2008 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 14,600 MILES
Electrical problem
2008 Honda Accord 4 cyl Front Wheel Drive Manual 14600 miles
I used my wipers this morning on "single sweep" mode. They stayed on, refusing to turn off. I cycled through all the speed settings to no avail. Then, I tried the "wash" function, and they did stop eventually.
I can't replicate the "stuck on" problem, but now the wipers are not parked all the way down. I''m guessing the wiper motors might be the problem?
BLUELIGHTNIN6
  • 16,542 POSTS
Most lilkely is a faulty wiper motor, but I would start with checking the wiper relay. If relay is bad and sticking it can also cause these symptoms.
JERRIP
  • 1991 HONDA ACCORD
  • 4 CYL
  • FWD
  • 176,000 MILES
Electrical problem
1991 Honda Accord 4 cyl Front Wheel Drive Automatic 176000 miles
Wipers won't turn off after you turn them on without key to engine turned off.
It also happens when you turn on the cruise control. It does have the intermitent switch. We have tried replacing the wiper motor with one from a junk car. Still have probelm with it not turning off. What else shoud hubby check? He is a mechanic so technical stuff should not be a problem. This car year model was when he was working still for Nissan so he is not sure what it is and what and how to check. Things we think it could be is the chassis contol unit (mulitfunction control unit integrated) or maybe a replay.
F4I_GUY
  • 3,302 POSTS
Tell him to check to see if the wiper multi-function switch is still sending power to the motor after you turn them off. The switch is located on the steering column.
PEPSTA96
  • 1995 HONDA ACCORD
  • 4 CYL
  • 151,000 MILES
Electrical problem
1995 Honda Accord 4 cyl Two Wheel Drive Automatic 151000 miles
My power window behind the passnger seat will not go up. Also, (this just started 2 wks ago and happens every day) the green light around the "D" on the dashboard starts blinking, it turns on and off.
And one more thing please, can you tell me how to take off the old windshield wipers and how to put the new windshield wipers on? Thanks for you time.
KHLOW2008
  • 41,815 POSTS
Hi pepsta96,
Thank you for the donation.
You need to test the window motor. It could be the master switch, door switch or wiring problem.
When the D4 light is blinking, a fault has been detected in the trans control system and you need a scan to check it.
Bridge the SCS terminals and count the blinks on the D4.
Press the unlock tab of the wiper blade mount clips to release the wiper.
DAZZLINGDANZLE
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 143,000 MILES
Electrical problem
1998 Honda Accord 4 cyl Front Wheel Drive Automatic 143000 miles
I just got this car like 2 weeks ago, when I first got the car the windsheild wipers were completley gone. I went and bought new ones and when I turned them on the first speed was constant, and I thought to myself 'hmm, thats pretty fast for just the first speed' and when I stopped the car at the stop light the windsheild wipers automatically slowed down. They would then speed up when I drove. So I thought to myself that it was weird, but kinda cool that they did it. Then the other night I went to use my windsheild wipers, and they didn't do the same thing. The first speed was slow, so I put it on the second one. But when I would stop my car the windsheild wipers would go below my windsheild and smack the bottom (where the plastic is, where they usually sit when they are turned off) but when I drive off, they don't smack the plastic part they stay on the actual glass.
So I don't know if my motor is going out? Or if there is some kind of electrical problem. I need help!
KHLOW2008
  • 41,815 POSTS
Hi dazzlingdanzle,
Seems the wiper motor linkages might have worn off resulting in the inaccurate ans slow or fast movement. Lift the wiper arms and try shaking the base, if there are a lot of side travel, the pivot is worn and needs replacement.
SIRPEEKAY
  • 1991 HONDA ACCORD
  • 1.6L
  • 4 CYL
  • FWD
  • MANUAL
  • 249,000 MILES
Hi, wondering if you had any suggestions why my wipers come on when I start the car, stay on and wont turn off, (doesn't happen all the time, just quite often, )many thanks
Saturday, April 22nd, 2017 AT 7:23 PM (Merged)
  • 108,179 POSTS
There has to be a short to power causing the wiper motor to get power. It could be in the switch itself or any place in the wiring for the wipers.
SRACCORD
  • 1996 HONDA ACCORD
  • 155 MILES
I Have a 1996 Accord. The dealer replaced the wiper blades last week and the first time I used the wipers, I could not get them to turn off. This happens every time. They stay on for 10 minutes or so and I am finally able to turn them off. Is this a weird coincidence, or did they do something when they put the new blades on and tested? Seems like TOO much of a coincidence to me.
  • 52,797 POSTS
No, nothing to do with the replacement of the wipers. It would have happened even if you did not have the blades replaced.'
the parking circuit in the wiper motor is failing and the motor needs to be replaced.
LAURAHONDAACCORD
  • 1997 HONDA ACCORD
Electrical problem
1997 Honda Accord Two Wheel Drive Manual 174000 miles
My windshield wiper fluid dispenser didn't work since I bought the car a few months ago. Suddenly yesterday, in very cold conditions, the dispenser started working and would not turn off! Now today, I am seeing several electrical issues, such as the brake lights not turning off even with the vehicle turned off. Where should I start?
BRUCE HUNT
  • 3,753 POSTS
It often points to the alternator. I would have it tested. The brake light issue might be the switch at the brake pedal.
ETOMA
  • 2003 HONDA ACCORD
  • 6 CYL
  • 102,000 MILES
Electrical problem
2003 Honda Accord 6 cyl Two Wheel Drive Automatic 102000 miles
I need to replace wiper linkage. Trying to access the linkage and the diagrams I have show two different types of hood seals on the cowl covers. Diagram shows at least 10 seals to remove...I only find 4 seals and the cowl covers don't come off. Are my instructions off? I'm using autozone diagram :http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?chapterTitle=Windshield+Wipers+And+Washers&partName=Chassis+Electrical&pageId=0900c1528026eb4c&partId=0900c1528026eb28
Any help/input is appreciated.
KHLOW2008
  • 41,815 POSTS
Hi EToma,
Hope this diagram helps.
https://www.2carpros.com/forum/automotive_pictures/192750_WiperRemoval03AccordFig15_1.jpg
MTVM43
  • 1996 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 300,000 MILES
Wipers will not turn off on 1996 honda accord
KHLOW2008
  • 41,815 POSTS
Wiper is linked to the Integrated Control Unit plugged into the underdash fuse box and is known to fail.
