1991 Honda Accord miss fire
STEVENKEEHNER
  • 1991 HONDA ACCORD
  • 4 CYL
  • 194,000 MILES
My car just started miss firing lately. It only does it in drive, not in park. It also does it around 1000-2000 rpms. Instead of a smooth acceleration it goes " vrooom put put put put vrooom. If I hold the brake and accelearate it hesitates around 1500 rpms, just put put put is all I get, but it gets over it at a higher rpm and runs smooth then.. I changed my spark plugs their wires and seals around valve gaskets. Is there a way I can fix this?
Do you
have the same problem?
Monday, March 17th, 2008 AT 3:53 PM
You might as well give it a major tune-up and see what happens-if not come on back and we''l get into the fuel and ignition system.
Monday, March 17th, 2008 AT 4:33 PM
BMRFIXIT
  • EXPERT
What I would do is complete the tune up as change the wires cap rotor and check the coil
which design u have for the coil is it in the cap or out
look for an oil leak in the distributor and the cap
distributor may be at fault too check it out
Monday, March 17th, 2008 AT 4:37 PM
Recommended Guides
