1990 Honda Accord Coolant Temp Rises at Stoplight
YELOC5
  • 1990 HONDA ACCORD
  • 4 CYL
  • FWD
  • 162,000 MILES
When I stop, the temperature gauge rises above the normal level, but hot as high as the red level on the gauge. As soon as I go, the temp goes back to normal almost immediately. I can also bring the temp to normal by revving the engine a little while I am stopped. The cooling fans are working properly, and the radiator is only a few years old. Last time I checked, the coolant looked good, but I needed to add about a pint.
Could this be a sign that my water pump is going bad?
Do you
have the same problem?
Tuesday, March 23rd, 2010 AT 6:59 PM
Try replacing the thermostat and go from there.
Wednesday, March 24th, 2010 AT 2:06 AM
Recommended Guides
