1990 Honda Accord
DREAMZ_GURL8806
  • 1990 HONDA ACCORD
1990 Honda Accord
I have a 1990 Honda Accord 4dr and the problem is that sometimes I can't start the engine. It's like it'll not start and then we leave it for a few hours and restart it again then bam it works again perfectly fine. I don't know what to do. I've wasted alot of money fixing this and it seems like the problem is still there and nothing has changed. If you can, can you please help me, because i'm tired of getting stuck at work or school like this. I think that maybe its due to the heat. But I want to know what the problem is with the car so I can fix it? Why does my car keep doing this?
Do you
have the same problem?
Monday, September 15th, 2008 AT 7:54 PM
LEGITIMATE007
  • EXPERT
Check basics, fuel, and spark(ignition), and also check the mass airflow sensor along with the airfilter and breather, if the breather is saturated, replace it with a new one, change air filter and change pcv valve.
Monday, September 15th, 2008 AT 8:00 PM
LEGITIMATE007
  • EXPERT
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
LEGITIMATE007
  • EXPERT
http://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Monday, September 15th, 2008 AT 8:01 PM
Recommended Guides
