Where is the fuel pump relay located? No power to the fuel pump.
Wednesday, July 28th, 2010 AT 4:56 PM
MECHANIC
The Fuel Pump Relay is incorporated into the PGM-FI Main Relay. Main PGM-FI Relay
Main Relay (incl. Fuel Pump Relay)
SPONSORED LINKS
Wednesday, July 28th, 2010 AT 8:54 PM
JULIETAYLOR
MEMBER
1 POST
Does the fuel pump have a reset button for fuel pump
Sunday, April 7th, 2019 AT 1:50 PM
KEN L
MASTER CERTIFIED MECHANIC
Not on this car, Ford is the only manufacturer that has an inertia switch.
Tuesday, April 9th, 2019 AT 2:09 PM
LBRENNEN
MEMBER
1 POST
1990 HONDA ACCORD
Computer problem
1990 Honda Accord 4 cyl Two Wheel Drive
Where is the fuel pump and injector relay located and do you know where I have find a picture of one for a 1990 honda accord ex
Wednesday, November 27th, 2019 AT 6:21 PM
(Merged)
OBXAUTOMEDIC
MECHANIC
Your Fuel Pump is located in the Tank. There is a injector resistor.
SPONSORED LINKS
(Merged)
NJMERCED
MEMBER
1 POST
1985 HONDA ACCORD
1985 Honda Accord 4 cyl Front Wheel Drive Automatic
we are trying to find the location of the fuel pump relay. Car will not start just changed fuel pump
(Merged)
BLUELIGHTNIN6
MECHANIC
Fuel pump cut-off relay is located behind the fuse / relay block, under the left side of dash.
(Merged)
THELMA LOUISE
MEMBER
1 POST
What does it look like.
(Merged)
VIC K
MEMBER
1 POST
1989 HONDA ACCORD
4 CYL
FWD
AUTOMATIC
126,300 MILES
I just bought a fuel pump relay from Honda and the parts person said it was located under the dash to the right of the steering column. I can't find it and wonder if I need to pull off the dash to access this part. Any help is surely appreciated. Thanks!
Wednesday, November 27th, 2019 AT 6:22 PM
(Merged)
KHLOW2008
MECHANIC
Hi vic,
It is located at the left of the steering column, mounted on the side panels underdash. You don't need to remove the dash, just get at it from underneath.
(Merged)
