1988 Holden Commodore OIL QUESTION
MAORI
  • 1988 HOLDEN COMMODORE
  • 6 CYL
  • MANUAL
  • 335,000 MILES
Hi
thanks for giving me the opportunity to further my knowledge about my car
well my question is , can you tell me why my engine oil is slightly a white-ish colour ?
i checked the dip stick to find the oil slightly white my engine was a RB30E but has now been converted to a RB30ET 3Ltr turbo . any help is so much appreciated
http://www.2carpros.com/forum/automotive_pictures/284217_TmpFile_3_1.jpg
http://www.2carpros.com/forum/automotive_pictures/284217_TmpFile_3_2.jpg
Do you
have the same problem?
Tuesday, December 9th, 2008 AT 10:23 PM
  • EXPERT
HI there,
These VL are very reliable but the turbo version engine re plant do have a problem cracking heads, I would do and engine flush first change the oil & filter a nd run it for a while, see if it starts to go milky, are you using any coolant? May be get a head check done, this takes just a few Minuit's and is fairly accurate, start here.
Mark (mhpautos)
Tuesday, December 9th, 2008 AT 11:06 PM
Recommended Guides
