Check engine light
MMD652
  • 2008 HYUNDAI TIBURON
  • 2.0L
  • 4 CYL
  • FWD
  • 60,000 MILES
Sometime in the summer my engine light started up without any 'real' noticeable problems but with time, I've tried several things overall to fix the problem. When a mechanic scanned my car, they said that it was a problem with the cooling system, so I switched the thermostat (for a new factory one) and the sensor that accompanies it. This helped slightly, and for a while, it was better, but again the problem has returned. THe heater works quite well, and the vehicle works well the majority of the time. Since it's winter in Canada, it has to withstand -50 degree (celcius) weather, so sometimes when I start it, it'll idle around 3000-4000 rpms. Does anyone have a similar problem? Help?
Monday, February 10th, 2014 AT 5:38 PM
HMAC300
  • 48,601 POSTS
We need the codes so we can go further with this.
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Tuesday, February 11th, 2014 AT 7:01 AM
THEOTIS HUBBARD
  • 2007 HYUNDAI TIBURON
  • 88,000 MILES
I have a 2007 tiburon the check engine lite comes on when it wants to and goes off when it want to I had it diagnostically tested at auto zone and the code they gave me was po711 transmission fluid temperature sensor where is the sensor located, what's th
Tuesday, December 31st, 2019 AT 11:22 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
Your details above were cut off can you please explain it again?
THEOTIS HUBBARD
I have a 2007 tiburon the check engine lite comes on when it wants to and it goes out when it wants to I had it diagnostically tested at auto zone ist said that transmission fluid temperature sensor code po711 and transmission control module code po700 where are those parts located, can they be disabled?
SATURNTECH9
  • 30,870 POSTS
You just cant go disabling things the light will stay on. From what I have seen usually the coolant temp sensor sets that code. What the code is saying is there is too great of a difference between the transmission temp verus the coolant temp after a certain amount of running.
ANGMEM
  • 2006 HYUNDAI TIBURON
  • 6 CYL
  • FWD
  • 67,000 MILES
My Hyundai 2006 Tiberon will not pass emissions and the engine light is on.
DOCFIXIT
  • 18,828 POSTS
Hi
Have codes read then post will advise. Have you gone to Dealer? 10yr 100,000 mile warranty
ANGMEM
Here are the numbers after the codes were read:
P0170
and
P0173
We took the car to Auto Zone and these are the codes that were read.
DOCFIXIT
  • 18,828 POSTS
Code is Fuel Trim(bank 1) HO2S signaling to many fuel adjustments to keep engine at optumim fuel. Possible causes air leak in intake or exhaust, dirty oil or level to high, front HO2S or MAFS contamination, fuel system fault, EVAP system fault.
Emissions covered for 10yr or 100,000 miles
MARIO1229
  • 4 CYL
  • FWD
  • 55,000 MILES
I had a diagnostic done. This is my wife's car now. I do not want to leave her and the baby stranded. These are the readings the diagnostic gave:
Open or short circuit condition
Poor electrical connection
Faulty EVAP vent valve
Are any of these costly? May I repair any of these myself? Could any of these leave my wife stranded?
  • 108,173 POSTS
They sound related. Chances are the connection the evap valve is loose or corroded causing the problem, or there is a broken or damaged wire to it. I would recommend having it looked at by a mechanic to determine the exact cause. Honestly, it shouldn't be too much money to repair, but make sure to get a quote prior to the repair.
Also, if I am correct, this problem shouldn't leave her stranded. It will, however, cause the vehicle to fail emissions inspection if you live in an area that requires it.
SARDNN
  • 2005 HYUNDAI TIBURON
  • 4 CYL
  • MANUAL
  • 66,000 MILES
I just recieved a check engine light and took the card to autozone to have them perform a check engine test. The codes that came back were P0171 and P0170? The most common problems were Syst too lean, faulty EVAP MAF, Ignition misfire repair, Blocked injectors, Ignition syst fault, fuel syst fault?
Lean fuel condition could be caused by one of the following below:
1. Vacuum leaks
2. EGR and PCV valve.
3. Low fuel pressure.
4. Dirty fuel injectors.
5. Mass Air Flow Sensor.
6. Oxygen Sensor.
CVELAZQUEZ26
  • 71,116 MILES
Was driving normal and it just pop up. I don't hear any typical sound at all or any smell.
SATURNTECH9
  • 30,870 POSTS
The first thing you need to do is have the car scanned for codes let me know the exact code numbers you have not code descriptions. Without them cant tell you much.
THELASTJACKELOPE
  • 2004 HYUNDAI TIBURON
2004 Hyundai Tiburon 6 cyl Front Wheel Drive Automatic 60K mi miles
Today, my 2004 Hyundai Tiburon had the check engine light come on. I couldn't help but notice it happened at the same time that my rear windshield wiper makes a clicking noise when turned on. The wiper still works fine, but right when engaged it makes one loud click. Any ideas?
Tuesday, December 31st, 2019 AT 11:23 AM (Merged)
  • 108,173 POSTS
What I need you to do is have the computer scanned. If the check engine light is on, there is a trouble code stored in the computer that will help identify where the problem is coming from. Have that done and let me know what you find. Note: Most nationally recognized parts stores will scan the computer for free.
TRICIAJO
  • 94,000 MILES
Check engine light came on. Obd2 codes are p0452 and p0449
P0449 †Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0452 †Evaporative Emission Control System Pressure Sensor Low Input
TRICIAJO
Is this an expensive fix and do I need to do it immediately or can I wait a couple months till I can save up for it
