Help
BRIDGET89
  • 2002 HONDA ACCORD
  • 197 MILES
This morning my car reversed fine but as I was going down the road I switched gears and now it won't and I reverse I've never had transmission problems. It's an automatic drive. Oz help what could it be?
Do you
have the same problem?
Friday, May 10th, 2013 AT 8:06 AM
HMAC300
  • EXPERT
Scan for codes and check trans fluid if you can
Friday, May 10th, 2013 AT 9:46 AM
BRIDGET89
I just got it scanned and the code was p0730. Is this an easy fix?
Saturday, May 11th, 2013 AT 10:16 AM
HMAC300
  • EXPERT
It means you have a defective shift control system in your transmission. This can be anything from bad shift valves to a shorted wire so have a trans guy check it out, it may be a common occurance and he can let you know how best to fix it. It may also time for a rebuild on the trans as well.
Saturday, May 11th, 2013 AT 1:17 PM
Recommended Guides
