Four wheel drive issue
BRIAN POWELL
  • 2010 CHEVROLET S-10
  • 4.3L
  • V6
  • MANUAL
  • 15,300 MILES
Will I lock my truck in four wheel drive. It is push button and go to pull out to go it pops bad in the front right side you can feel it in the wheel bad and the same side and pulling. I do not know if it is limited slip or if the cv axle has play in it. Could the cups in the cv axle be that bad they are just jumping or could it be the front end on the right side not locking in all the way?
Do you
have the same problem?
Tuesday, May 24th, 2016 AT 8:33 PM
HMAC300
  • EXPERT
Have axles checked for broken cv joints.
Wednesday, May 25th, 2016 AT 6:38 AM
Recommended Guides
