Heater blower motor dose not work
DAISY DOG
  • 2002 DODGE RAM
  • 5.9L
  • V8
  • 4WD
  • 140,000 MILES
Electrical problem
2002 Dodge Ram V8 Two Wheel Drive Automatic
I have been having this issue for sometime now, and I know it is not the blower motor, blower motor resistor, a/c controls or any fuses that have went bad.
I was told that there is a wire that connects from the blower motor to somewhere under the steering column. I have noticed that if I open the access panel under the steering column, and give a slight movement of the lines under there, the motor cuts on and off.
Can anyone specify which wire or set of wires it is that is causing this issue
Do you
have the same problem?
Sunday, March 9th, 2014 AT 6:11 AM
KNOWLEDGE IS POWER
  • EXPERT
Here is a diagram. Let me know if it helps
Sunday, March 9th, 2014 AT 7:43 AM
Recommended Guides
