Heater blend foor actuator motor wiring diagram
MAVERICKMAN
  • 1997 PONTIAC BONNEVILLE
  • 3.8L
  • 6 CYL
  • FWD
  • 98,000 MILES
I pulled apart wire connector for blend motor on top of heater core cover. It has 3 wires but motor has 6 terminals onit. Which terminals do the yellow blue and brown wires each go to? Is one high voltd then medium and 3rd a lower volt? Or is one a ground? Can u plse send me a wire diagram? Thannk you so much for your help!
Do you
have the same problem?
Sunday, January 19th, 2014 AT 1:49 PM
HMAC300
  • EXPERT
See pic blend door is 7 8 10 at bottom of pic
Tuesday, January 21st, 2014 AT 6:33 AM
Recommended Guides
