Heat will not come out vents un less RPM is above 3000
CLAYM11
  • 2006 BUICK TERRAZA
  • 2.6L
  • 6 CYL
  • 80,000 MILES
I replaced water pump and thermostat and now heat will only come out vents when rpm is above 3000. Some times temp gauge will go up to 3/4 then come back down. Below 3000 rpm it blows cold air only.
Do you
have the same problem?
Sunday, December 15th, 2013 AT 4:40 PM
  • EXPERT
Is the coolant full? Did you bleed the system?
Sunday, December 15th, 2013 AT 5:03 PM
Recommended Guides
