Headlights not working
BRADLEY BARNETT
  • 2000 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 96,000 MILES
I have no headlight on my truck listed above base model with 4.3 v6. I have replaced both relays and fuses are good. Front corner lights work fine as do rest of the lights. I can ground the headlight directly and they come on. I have checked the grounds and clean them up. Any ideas? I also have replaced the headlight switch.
Do you
have the same problem?
Wednesday, May 15th, 2019 AT 10:43 AM
  • EXPERT
Welcome to 2CarPros.
If you cleaned the grounds and have continuity to ground, my first suspect is the headlight grounding relay is bad. The relay is located in the body relay block on the left side of the dash. I have attached two pictures to help you locate it.
Here is a link that explains how to test a relay:
Here are other links you may find helpful:
Check that and let me know what you find or if you have other questions.
Wednesday, May 15th, 2019 AT 8:03 PM
