Having battery light on caused by cluster
MRNICE
  • 2008 HYUNDAI ACCENT
Alternator and battery check out as good. Belts are firm grounds are good and all fuses are good also. Its now narrowed down to ecu and cluster. I have unplugged the cluster fuse and I found the car ran better!
Do you
have the same problem?
Wednesday, October 16th, 2013 AT 8:26 AM
  • EXPERT
Do you have a question? Not sure what you need.
Wednesday, October 16th, 2013 AT 8:30 AM
Recommended Guides
