Transmission failure between second and third
GERT00724
  • 2006 FORD TERRITORY
  • 4.0L
  • 203,000 MILES
I think I have electronic problem with my vehicle. I have some fault codes on it. And think it is my problem. For not shifting to third and fourth. RCM restraint control module. (SRS ) Ben body elect module. Him HVAC integrated module ICM instrument cluster module. TCM transmission control module speed sensors ABS/etc anti-lock brake module PCM power train control module. A lot of module problems. Can you reboot them like a PC?
Do you
have the same problem?
Thursday, May 11th, 2017 AT 11:42 PM
STEVE W.
  • EXPERT
With all those problems a hard reset might help but I think you might need a dealer to did through the main communication bus and see what is wrong as it sounds like a bus failure.
To try a reset, Disconnect the battery cables. Now hold the two cable ends so they touch for about 30 seconds. Now re-connect them. Try the vehicle. I'm going to guess it didn't help but?
Monday, May 15th, 2017 AT 2:04 PM
Recommended Guides
