1991 GMC Truck
1991 GMC TRUCK
210,000 MILES • V8 • 4WD • AUTOMATIC
1991GMC4X4
i need to find out how much tranny fluid a 700 gm tranny needs. i need the total amount of gallons or ounces needed.please
Feb 13, 2010 at 10:25 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
unless you are changing the fluid try to find a manual that is close to that and look under technical specs. it will give it to you. But if you are changing all thefluid then it's somewhere around 11 quarts. maybe 12.
Feb 16, 2010 at 12:48 PM
