1999 GMC Suburban runs for a couple of seconds
BRAINDEADSOB
  • 1999 GMC SUBURBAN
  • V8
  • 90,000 MILES
My 1999 gmc suburban runs for a couple of seconds the dies. There are no codes, fuel pressure is 60 psi when I turn the key to the on posistion, then drops to 56 psi when the pump kicks out. There is no security warning I disconnected the crankshaft sensor then it would'nt fire at all. Someone thinks its a malfunctioning pressure regulator.
Do you
have the same problem?
Monday, June 22nd, 2009 AT 10:56 AM
The fuel pressure should be 60-66psi
Monday, June 22nd, 2009 AT 11:16 AM
Recommended Guides
