HVAC Vent controls
JIM2002
  • 2002 GMC SONOMA
  • 6 CYL
  • 4WD
  • 102,000 MILES
I am having trouble with the Defrost/Feet/Vent/AC control. It is a 2002 GMC Sonoma with ZR5 Package. When I go to put the air to blow on my feet or defrost nothing happens. I can turn the switch over to the AC mode and it will start blowing cold air. It still comes out the 4 vents (face). It only blows out of the 4 vents that point at my face. It will switch to AC and the AC works fine but it still only comes out of the 4 vents on the dash by my face. I use to be able to hear it switch and I no longer even hear it trying to switch.
Any ideas as to what is wrong?
Wednesday, February 25th, 2009 AT 8:52 AM
SERPENTRACER
  • 34 POSTS
There is a mode blend door actuator that sounds like it is not working correctly here is a guide to help you fix the problem.
Saturday, February 28th, 2009 AT 7:22 AM
WIBRACKENS
  • 0 POST
Thank you for this post I had this problem and had to replace the mode actuator cost me $64.00 all fixed I love this site.
Tuesday, November 12th, 2019 AT 11:26 AM
SLV123
  • 2001 GMC SONOMA
  • 6 CYL
  • 4WD
  • 36,000 MILES
I am getting all the heat through the top vents OR the defrost and it wont blow out on the floor! Can you help?
Tuesday, November 12th, 2019 AT 11:27 AM (Merged)
ROBBIET
  • 8 POSTS
Sounds like you likely need to check your vacuum hoses for cracks and breaks. Can't tell u where they all are, but you'll have to poke around unless the dealer can give you a schematic printout of where they run.
TROYLEBLANC
  • 2000 GMC SONOMA
  • 6 CYL
  • 4WD
I have a 2000 GMC Sonoma, and I can't get any heat, but the heater cord is not plugged. Wondering if something turns it from hot to cold.
Check the thermostat if okay inspect the air blend door if its in the heat position
TROYLEBLANC
How do find that
