2000 GMC Sierra No Heat
HATMAN
  • 2000 GMC SIERRA
  • V8
  • 4WD
  • 16,500 MILES
I get very little heat.
I just replaced the thermostat and nothing changed.
I was ideling for 15 minutes and the upper hose was hot to touch, but not to the point where you couldn't hold it. The lower hose was cold to touch.
Also, when draining the radiator, the fluid would trickel out and would only drain after I blew into the hose from the resivior tank.
Thanks.
Do you
have the same problem?
Monday, February 23rd, 2009 AT 9:24 AM
Check the radiator if its clogged-up and the water
Monday, February 23rd, 2009 AT 9:32 AM
Recommended Guides
