1998 GMC Sierra Fuel
DWTKROMM
  • 1998 GMC SIERRA
Engine Mechanical problem
1998 GMC Sierra V8 Two Wheel Drive Automatic
What do I do to bleed or return fuel pressure after running out of gasoline
Do you
have the same problem?
Friday, April 30th, 2010 AT 8:47 PM
INTERNETMECHANIC
I'm not sure of engine litre size? When you first turn the key on, no crank, can you hear the pump run? Use a gage and check fuel pressure. The fuel pressure gage has a bleeder valve on it, usually a clear plastic hose that you aim into proper container, to bleed. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one.
Saturday, May 1st, 2010 AT 4:04 PM
Recommended Guides
