1995 GMC Sierra wont start sometimes
TOM_CAWKER
  • 1995 GMC SIERRA
  • V8
  • 4WD
  • 210,000 MILES
I have a 95 gmc sierra 5.7 litter 4x4 K1500 and for the last few days it has been going through gas like crazy sometimes it wont start and some times it will wen I start it in the morning it will start and then stall and then it will start again but only after cranking it till the battery almost dies wen it is running it seems to run good but does not seem to have the power it should have for a 350 after driving it for a bit I turn it off and it wont start it just turns over and over but if I let it sit for a few hours it will start but not easy at all but wen it does it runs till I shut it off and wamo it does it again also when ignition is on no dash lights like check engine will not come on all the time when it does the fuel pump works any ideas would be great thanks my email is kooter6@hotmail. Com found the prob if any body ever has this prob here is what I did to fix it underneath the stering wheel take the cover off and there is a cluster of wires there going into the ignition switch push gently or tap lightly and and dashlighs came on and the truck started could been lose plug or might have to chang ignition switch thanks
Do you
have the same problem?
Friday, January 30th, 2009 AT 8:31 AM
BILLYMAC
  • EXPERT
Sorry no question here
Saturday, January 31st, 2009 AT 11:01 AM
Recommended Guides
