1995 GMC Sierra prnd21 light stays on all the time
ADAMRANGER1
  • 1995 GMC SIERRA
  • 6 CYL
  • 4WD
  • 190,000 MILES
I have a 1995 GMC sierra pickup and I have a problem with the battery constantly draining I check as many connections as I could and I found that the shifter position light stays on all the time. Even with the key out of the ignition. Everything else functions correctly. I only drive this truck on the weekends and by the time the weekend comes around the light drains the batteryl. I have started pulling the fuse that controls this light to save my battery but it is a pain. Do you have any advise.
thanks
Do you
have the same problem?
Saturday, December 19th, 2009 AT 6:36 AM
KHLOW2008
  • EXPERT
Hi adamranger1,
Thank you for the donation.
The Park and Neutral switch should not have any power supply when the ignition switch is turned off so there could be a bad relay somewhere. I need to confirm the following to get the correct information.
What is your engine capacity?
Is this a C or K series? C1500, C2500, C3500, K1500, K2500 or K3500?
Saturday, December 19th, 2009 AT 11:37 PM
Recommended Guides
