1992 GMC Sierra
KENNY12
  • 1992 GMC SIERRA
  • V8
  • 4WD
  • 162,000 MILES
I HAVE NO POWER TO MY IGNITION-ALL LIGHTS WORK BUT DO NOT SEEM TO GET POWER TO THE DASHBOARD OR IGNITION SWITCH-BATTERY IS CHARGED CHECKED IGNITION FUSE-GOOD-BY THE WAY IT IS 30 BELOW ZERO HERE
Do you
have the same problem?
Tuesday, February 9th, 2010 AT 8:49 AM
JDL
  • EXPERT
Hi, if your saying the dash gages don't work, check the gage fuse, use a testlite, the circuit goes hot when you turn on the key. In the diagram, red wires carry voltage to ignition switch. Pink wire carries voltage to gage fuse. I enlarged it several times, still may not be readable?
http://www.2carpros.com/forum/automotive_pictures/170934_gmc_ignition_switch_1.jpg
Tuesday, February 9th, 2010 AT 9:32 AM
Recommended Guides
