1997 GMC Safari wont start
KOKO0866
  • 1997 GMC SAFARI
Engine problem
1997 GMC Safari 6 cyl Two Wheel Drive Automatic 110.00 miles
my 97 gmc wont start I changed the fuel pump and the fuel filter also I replced the air filter and battrie I put a bottle of antifreez for the gas lines and a bottle of fuel injector and carb cleaner?
Do you
have the same problem?
Sunday, December 30th, 2007 AT 1:21 PM
PJ(GTO)
When you turn on the car to the start position, do you hear a hum in the back? (The fuel pump) I know you replaced it but if it is still not pumping, the problem could be a fuse locaded under the hood, I believe it is locaded near the relays on the passanger side near the radiatior.
If the pump is humming when you turn it on, see if you have spark.
Sunday, December 30th, 2007 AT 1:28 PM
Recommended Guides
