1992 GMC Safari Fuel system
MOELALON
  • 1992 GMC SAFARI
  • 6 CYL
  • 130,000 MILES
Engine sputtered for several minutes like a fuel problem was happening
I replaced the fuel pump, fuel filter and assembly, and sending unit, cleaned the tank, tested the pressure (15 psi).
what else could it be?
Saturday, July 24th, 2010 AT 2:32 PM
Hi moelalon, Welcome to 2carpros and TY for the donation
Is this a 4.3l engine or 4.3l with a turbo? Also is it a TBI or CPI injection system?
TBI pressure should be: 9-13psi
CPI spider assy should be 54-64psi-Please confirm-NOTE: CPI injection its way too low-could be the pressure regulator, fuel pump check valve leaking or a weak pump
Saturday, July 24th, 2010 AT 4:17 PM
MOELALON
  • 9 POSTS
Fuel pump is new. TBI model 220 4.3 L no turbo. Fp comes on for 2 seconds when cranked but won't start. No fuel to TBI. Gets fuel to new fuel filter. Relays have power to them and pump comes on okay. No damage to lines. New clean fuel in tank.
What could it be?
Started and ran good for 2 months. Idle was fast though
Wednesday, July 28th, 2010 AT 4:27 PM
Check the fuel pressure with a gauge to rule out a defective new fuel pump if okay -also check if the injectors are pulsing
Wednesday, July 28th, 2010 AT 5:45 PM
MOELALON
  • 9 POSTS
Already checked the pressure on pump 15psi. And the injectors are pulsing.
What else?
Friday, July 30th, 2010 AT 7:49 PM
If the injectors are pulsing it should be getting fuel to the cylinders-you can see this while cranking it over if so-Check if you are getting spark
Friday, July 30th, 2010 AT 7:54 PM
MOELALON
  • 9 POSTS
I am getting spark. Fuel is not flowing to TBI. No fuel is coming through fuel line at TBI carburator.
Friday, July 30th, 2010 AT 8:17 PM
How did you get the fuel pressure and how did you do it.
You got fuel pressure that's over 2psi, injectors are opening and closing meaning its pulsing *****( fuel is not flowing to TBI )***** I don't understand this part
Saturday, July 31st, 2010 AT 2:11 AM
MOELALON
  • 9 POSTS
I tested the fuel pressure at the fuel filter.
I disconnected the fuel line at the carb. Or TBI as it is called on this model. There is no gas flow to the throttle body injector.
Saturday, July 31st, 2010 AT 8:49 AM
If you are gettig fuel pressure up to the TB and injectors are pulsing and not going thru replace the fuel pressure regulator to do this you have to replace the fuel metering body
Saturday, July 31st, 2010 AT 9:06 AM
MOELALON
  • 9 POSTS
I just said that I WAS NOT getting fuel pressure to the TB
read the thread again. You don't seem to understand
Saturday, July 31st, 2010 AT 7:16 PM
If you're not getting fuel pressure up to the TBI then your fuel pump is defective-you got me confused here
Saturday, July 31st, 2010 AT 8:47 PM
Moelalon Posted: Fri Jul 30, 2010 6:49 pm Post subject: 1992 Safari Van
What else?
Dunno know where you stole your 15 psi this the problem that's giving me the curve ball either you have it or not and thanks for your negative feedback. Be advised I know this TBI back in the early 80's in and out been in this business 41yrs and still at it. Your the one that needs to comprehend your problem, not me am just here to help you all the way as possible-You are one backing stabbing person. You will shoot a person behind his back not looking. Do you want your donation back? How much was it and I'll return it-don't need your nickel and dimes. The problem is right under your noise-BTW I almost forgot I've rendered my services to you and you ain't getting it back-you still owe
Saturday, July 31st, 2010 AT 9:04 PM
