HELP
SCOTTYO
  • GMC
I HAVE A 91 BUICK CENTURY I GOT MAD AND HIT THE HORN THE HORN MAGICALLY WENT OFF AT 3 AM.I HAD TO UNPLUG THE HORN. NOW THE FUSE FOR THE ACCESORIES KEEPS BLOWING I TRIED FUSE AFTER FUSE SAME AMP HIGHER AMP ETC. SEEMS THE RADIO ISNT WORKING EITHER EVEN THOUGH THE RADIO HAS ITS OWN FUSE CAN ANY 1 HELP BEFORE I SCREAMMMM :evil: THANX FOR ANY REPLY
Do you
have the same problem?
Thursday, March 23rd, 2006 AT 8:50 AM
JPAM
You pnuch horn and sometime later at 3am it went off? And all your other problems are next.
Sounds like the horn on steering wheel could be shorting out. Id get at your horn (on steering wheel)and take a look to see if anything was damaged or just disconnect wire for horn(in steering wheel)
and see if it helps.
Good luck and let us know. Jess s
Thursday, March 23rd, 2006 AT 5:28 PM
Recommended Guides
