1999 GMC Jimmy
VICKIED1981
  • 1999 GMC JIMMY
  • 6 CYL
  • 4WD
  • 138,900 MILES
I just had my fuel pump replaced but my gas gauge is still not working and my battery light is on my temp gauge isn't working and when I put the car in reverse or drive it doesn't light up. We have checked all the fuses including the one under the hood and they are all goods. Also I have the thing that shows the direction and outside temp and stuff and that is not working either. What could be the problem with all of thes? Thanks for your help
Do you
have the same problem?
Tuesday, August 31st, 2010 AT 7:29 PM
MADMIKE1735
  • EXPERT
Well lets start with one thing. You had your fuel pump replaced recently. Why was it replaced? The sending unit is what sends a signal to the gauge letting it know if the tank is full or empty. They are not cheap. A fuel pump will have nothing to do with the gauge, unless while it was changed something was left unplugged, or a ground is disconnected.
Tuesday, August 31st, 2010 AT 7:37 PM
Recommended Guides
