1995 GMC Jimmy starting
DEB BERGEN
  • 1995 GMC JIMMY
  • 6 CYL
  • 4WD
  • 201,200 MILES
The weather is nice just a little damp but if my jimmy is not plugged in it will not start. There is a new distributor cap and router put on it and the issue still stands. I can hear the fuel pump coming on and off as you turn the ignition but all the vehicle does is fire ans will not turn over but if you plug it in for about 2 hours, no less, it will start first turn. Is driving me nuts. Did a scan and the computer says there is nothing wrong, no error codes in the history.
Do you
have the same problem?
Tuesday, March 9th, 2010 AT 1:33 PM
Check and test the coolant temperature sensor
Tuesday, March 9th, 2010 AT 2:31 PM
Recommended Guides
