Envoy speedometer not working
CTFAMILLER
  • GMC ENVOY
2004 Envoy speedometer on 60,000 mile vehicle
Odometer works sometimes but at other times it is all over the place - may show 100MPH
not predictable
Tuesday, October 23rd, 2007 AT 10:31 AM
It sounds like the vehicle speed sensor has gone out here is the location. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, November 15th, 2007 AT 7:08 PM
OIDAVEY
  • 0 POST
Thanks for this post I had this problem and had to get a new sensor cost me $67.00 all fixed! I love this site
Wednesday, February 27th, 2019 AT 1:32 PM
MARK FRIZZELL
  • 141 POSTS
  • 2005 GMC ENVOY
  • 4.2L
  • AWD
  • 228,000 MILES
Changed cluster because tachometer and speedometer did not work, after change, tachometer now works, everything on vehicle works fine except speedometer. I put my solus on, no codes. I did a cluster sweep check everything works, also changed speed sensor.
Kind of lost here.
Wednesday, February 27th, 2019 AT 1:32 PM (Merged)
HMAC300
  • 48,601 POSTS
Check wire to see if it is broken or to much resistance like partially grounding out. It may need programming if you have not already done that.
MARK FRIZZELL
  • 141 POSTS
I have not been able to establish a program procedure for the speedometer, was replaced with known working cluster from same year. I do know that then BCM was replaced before I got it for other issues.
HMAC300
  • 48,601 POSTS
I think that may be the problem is it needs to be programmed to the car like the whole dash even if everything works.
MARK FRIZZELL
  • 141 POSTS
I have Mitchell software have not been able to find anything about programming speedometer.
JTHURMAN89
  • 2004 GMC ENVOY
  • 6 CYL
  • 54,000 MILES
My speedometer is not working properly. Sometimes I can be speeding and it will be on about 20 mph. Sometimes it won't go up at all, just sit on 0.
Inspect and test the vehicle speed sensor located left rear of transfer case
https://www.2carpros.com/forum/automotive_pictures/12900_vss_18.jpg
MARK FRIZZELL
  • 141 POSTS
I think I just found my answer, I will have to take it get it programmed.
MARK FRIZZELL
  • 141 POSTS
Thanks, I appreciate your answers.
STEVE W.
  • 12,963 POSTS
Most newer clusters are VIN locked. They need to have that updated to allow it to display speed and miles. Takes a dealer code to let you get to the VIN lock.
ILLINIJEFF
  • 2005 GMC ENVOY
  • 6 CYL
  • 112,000 MILES
After I drive around 250 miles my speedometer slowly starts to drop and after time sits below zero. Once I get to my destination and turn the car off for a while it starts to work again. What could cause this? Thanks! Go Air Force!
MMPRINCE4000
  • 8,549 POSTS
Contact GM about a TSB (technical service bulletin) concerning erratic speedometer operation.
This should be a free or reduced cost repair.
RWNEAL
I too am having similiar issues. We first noticed it started happening when the cold weather hit (and it didn't happen all the time). Since then, it has become a common occurance, regardless of weather - almost all the time. I can be driving 30 mph, and the speedometer reads 70'ish with no apparant correlation to the actual speed traveling.
Is there a TSB # that I can reference when making the call? The last thing I want to do is be on hold for a while and then not be able get any help.
