1993 GMC C1500 wipper motor replacement
KEITH W. VAUGHT
  • 1993 GMC C1500
  • V8
  • 350,000 MILES
I replaced my wipper motor, and now some how got out of adjustment. Some times they will wipe and some times they don't. I did notice that when the wippers do work they go pasted the normal spot to park at. If you can tell me how to get the motor back in time with the controler, I will be very greatfull. I did not find any info in my chiltons repair book for this truck ether.
Do you
have the same problem?
Wednesday, May 19th, 2010 AT 4:13 PM
BLUELIGHTNIN6
  • EXPERT
Hello and thanks for donating
You say that sometimes the wipers work and other time they will not come on? That would not be an adjustment issue, it sounds like there is still an issue with the wiper system. The biggest problem with these GM wiper systems is the circuit board in the wiper motor fails, did you use a used replacement wiper motor?
Wednesday, May 19th, 2010 AT 4:28 PM
Recommended Guides
