1985 GMC C1500 RADATOR
PETE3008
  • 1985 GMC C1500
Engine Cooling problem
1985 GMC C1500 V8 Two Wheel Drive Automatic
I HAVE A TRUCK THAT WAS RAN HOT. I REPLACED HEAD GASKETS AND NOW IT SEEMS TO NOT BE COOLING. NO OIL IN WATER OR VICE VERSA. WATER GETS EXTREMELY HOT AND SEEMS TO VAPORIZE IN RADIATOR
Do you
have the same problem?
Sunday, February 15th, 2009 AT 5:52 PM
  • EXPERT
Hi:
Have you had the coolant flushed? You may want to try that. Also, you mentioned problems that deals with head gasket. Is there w a problem with that. Fnally
Tuesday, February 17th, 2009 AT 9:40 AM
