GETTING NO SPARK, JUST STOPPED RUNNING!
ANDIDDIXON60
  • 1988 SUBARU GL
  • 150,000 MILES
JUST STOPPED RUNNING, NOW I HAVE NO SPARK BETWEEN PLUGS, ROTOR
iT WAS DRIVING FINE, I WAS GOING 40 MPH AND IT JUST QUIT. GOT IT TOWED HOME AND WHILE BATTERY DISTRIBUTOR AND IGNITAION SEEM FINE IT WILL NOT SPARK ENOUGH TO TURN OVER. PROBLEM APPEARS TO BE BETWEEN ROTORY CAP AND DISTRIBUTOR CAP, IS THIS A COMMON PROBLEM? THERE DOES NOT SEEM TO A BROKEN BELT ANY WHERE, QUESS IT COULD BE THE TIMMING CHAIN GEAR OR WHAT EVER. I DO NOT NEED A QUICK FIX RATHER A STARTING PLACE TO LOOK FOR WHAT THE GENERAL PROBLEM IS SO THAT I CAN FIX IT OR TAKE TO GARAGE AND GET A PRO TO TAKE CARE OF THE PROBLEM. I WAS GOING DOWN THE ROAD AND WE JUST CAN FIQURE WHAT HAPPENED GREAT LITTLE CAR SOLID AND TRUST WORTHY.
Do you
have the same problem?
Saturday, May 18th, 2013 AT 3:46 AM
KHLOW2008
  • EXPERT
Are you getting sparks from the ignition coil?
Saturday, May 18th, 2013 AT 2:04 PM
Recommended Guides
